 C3g engine head removal
ronenfe
MessageSujet: C3g engine head removal   Dim 3 Juin 2018 - 19:05
Can you help me to remove the head . Is there a tutorial here? I don't know how to remove the water pump and exhaust manifold.
MessageSujet: Re: C3g engine head removal   Dim 3 Juin 2018 - 20:32
Hello Hello Buy the technical magazine of the twingo
Toutes les fautes d'orthographe sont la propriété de l'auteur, et protégée sous le copyright, toute reproduction et interdite sous peine de poursuite et d'amende.
ronenfe
MessageSujet: Re: C3g engine head removal   Lun 4 Juin 2018 - 17:29
I have it online but I couldn't find clear instructions.
MessageSujet: Re: C3g engine head removal   Lun 4 Juin 2018 - 17:49
Hello I will do a search
MessageSujet: Re: C3g engine head removal   Lun 4 Juin 2018 - 18:10
ronenfe
MessageSujet: Re: C3g engine head removal   Lun 4 Juin 2018 - 18:17
Thanks, although the videos are for the newer engine, this is a good idea to search for the parts image and see their shape and holes.
I found also something here that may help:
http://forum.generation-twingo.fr/t2351-mecanique-faire-une-culasse-moteur-c3g-by-maladrye
MessageSujet: Re: C3g engine head removal   Lun 4 Juin 2018 - 18:56
Yes, even better! Wink
ronenfe
MessageSujet: Re: C3g engine head removal   Lun 4 Juin 2018 - 20:28
dany
MessageSujet: Re: C3g engine head removal   Lun 4 Juin 2018 - 20:37
Et en Français....... c'est pas possible.????
ronenfe
MessageSujet: Re: C3g engine head removal   Lun 4 Juin 2018 - 21:35
Sorry, I don't speak french, I'm using a translator.
dany
MessageSujet: Re: C3g engine head removal   Mer 6 Juin 2018 - 20:37
Bonsoir..... c'est nul.!!!
ronenfe
MessageSujet: Re: C3g engine head removal   Lun 11 Juin 2018 - 21:38
I removed the 2 nuts of the exhaust manifold using a 13 mm socket, an impact wrench and a flexible extension.
I Better find new nuts.
Anyone knows an online store which can sell Renault parts?
Do I have to keep track of each of the 10 head bolts locations or I can mix them?
ronenfe
MessageSujet: Re: C3g engine head removal   Mar 12 Juin 2018 - 0:28
Easier than I thought.
ronenfe
MessageSujet: Re: C3g engine head removal   Mer 13 Juin 2018 - 0:49
What do you think of the head, it has pittings and the black part on the left is sunken. [/url]
Jean-Claude Duss
MessageSujet: Re: C3g engine head removal   Mer 13 Juin 2018 - 8:22
Hi,
Do you easely find pieces for your car in Israel ?
ronenfe
MessageSujet: Re: C3g engine head removal   Mer 13 Juin 2018 - 8:37
This car was sold here for only 3 years with very small numbers. Very few still drives. Used to be easier. The dealer doesn't sell parts anymore. But I order from eBay mostly. It's much cheaper too anyway.
ronenfe
MessageSujet: Re: C3g engine head removal   Mer 13 Juin 2018 - 22:30
Does anybody know where those parts from the Ajusa gasket kit 52105000 should go?
ronenfe
MessageSujet: Re: C3g engine head removal   Dim 17 Juin 2018 - 23:32
My heating matrix is connected with the pants with the bleeding port connected to the bottom port and the other pants connected to the lower port.
But in this diagram it Should be the opposite. Can someone confirm the right connection?
ronenfe
MessageSujet: Re: C3g engine head removal   Lun 18 Juin 2018 - 0:19
ok, I see in the parts diagram it is connected properly.
ronenfe
MessageSujet: Re: C3g engine head removal   Mer 27 Juin 2018 - 10:33
Does anyone know which gasket is suitable for my car?
There are 2 options for c06.
What does the cross sign mean?
MessageSujet: Re: C3g engine head removal   Lun 2 Juil 2018 - 12:50
check on ebay:80026 walker  click hier
ronenfe
MessageSujet: Re: C3g engine head removal   Lun 16 Juil 2018 - 13:49
Are there any torque specs for the exhaust nuts and studs? and for the pump bolts and temp sensor plates? and valve cover?
ronenfe
MessageSujet: Re: C3g engine head removal   Mar 31 Juil 2018 - 20:50
I don't know how to keep the gasket in place while putting the head back on, it's heavy and I've already ruined one gasket.
ronenfe
MessageSujet: Re: C3g engine head removal   Dim 5 Aoû 2018 - 20:38
I did it. You have to be careful and only lower the head over the gasket vertically. I used 2 drill bits to make sure the gasket is locked in place in 2 corners, I removed one of them by hand and one of them from the head hole with tweezers.
