 Outer CV Joint is Stuck
ronenfe
ronenfe
Outer CV Joint is Stuck Empty
MessageSujet: Outer CV Joint is Stuck   Outer CV Joint is Stuck EmptyJeu 9 Juil 2020 - 0:44
Hi, does anyone know how to remove the outer CV joint? Haynes says to pry out one arm of the star retainer, and the shaft should come out. But it doesn't come out.
You can see one of the arms is pried out.
Outer CV Joint is Stuck Img_2012
Zou
Zou
MessageSujet: Re: Outer CV Joint is Stuck   Outer CV Joint is Stuck EmptyJeu 9 Juil 2020 - 9:36
Hi,
I found this:
https://www.diegoyourself.com/index.php?article=mecanique_roulement&page=8
The tutorial is in french, but it might help you
Edit: there's also a video at the bottom of the page
ronenfe
ronenfe
MessageSujet: Re: Outer CV Joint is Stuck   Outer CV Joint is Stuck EmptyJeu 9 Juil 2020 - 10:24
Thank you, that's a very good guide. Unfortunately there is no dismantling of the CV joint. Only instruction of how to remove the driveshaft and replace it with a new one.
Zou
Zou
MessageSujet: Re: Outer CV Joint is Stuck   Outer CV Joint is Stuck EmptyVen 10 Juil 2020 - 8:35
Sorry about that. But i have very limited mechanical knowledge; so i can't really help you
Si quelqu'un passe par ici et peut aider:
il voudrait savoir comment démonter la rotule de cardan elle-même, si j'ai bien compris !
» Conseil, merci... Joint cache culbuteur et pâte à joint...
» joint de porte supérieur Tw1
» [Resolu] D4F - changement joint d'arbre à cames
» joint échappement
