 C3g engine head removal (SUJET EN ANGLAIS)
ronenfe
ronenfe
C3g engine head removal (SUJET EN ANGLAIS)  Empty
MessageSujet: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyDim 3 Juin 2018 - 19:05
Can you help me to remove the head . Is there a tutorial here? I don't know how to remove the water pump and exhaust manifold.
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyDim 3 Juin 2018 - 20:32
Hello Hello Buy the technical magazine of the twingo
C3g engine head removal (SUJET EN ANGLAIS)  Rta-re10
C3g engine head removal (SUJET EN ANGLAIS)  Signat12
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 4 Juin 2018 - 17:29
I have it online but I couldn't find clear instructions.
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 4 Juin 2018 - 17:49
Hello I will do a search
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 4 Juin 2018 - 18:10
Sorry it's all in French, but here's what I found, in video and photo
https://www.google.fr/search?q=retirer+la+pompe+%C3%A0+eau+sur+twingo+1&client=opera&hs=PwZ&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjk_azBrrrbAhXFa8AKHbx6BOcQsAQIRg
https://www.youtube.com/watch?v=Scc5GcaTViY
https://www.youtube.com/watch?v=QnL5LbDka-U
https://www.youtube.com/watch?v=-4wVfmOiQ5c
https://www.google.fr/search?q=remplacement+pompe+a+eau+twingo+1.2+16v&client=opera&hs=o2Z&sa=X&biw=1383&bih=730&tbm=isch&tbo=u&source=univ&ved=0ahUKEwjD0Pf-r7rbAhXsJcAKHafyAaYQsAQITA
These photos are for the exhaust manifold
https://www.google.fr/search?q=retirer+le+collecteur+d%27%C3%A9chappement+sur+twingo+1&client=opera&hs=QAa&sa=X&biw=1383&bih=730&tbm=isch&tbo=u&source=univ&ved=0ahUKEwi5qtTfsbrbAhXFUZQKHeVvDesQsAQIQg
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 4 Juin 2018 - 18:17
Thanks, although the videos are for the newer engine, this is a good idea to search for the parts image and see their shape and holes.
I found also something here that may help:
http://forum.generation-twingo.fr/t2351-mecanique-faire-une-culasse-moteur-c3g-by-maladrye
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 4 Juin 2018 - 18:56
Yes, even better! Wink
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 4 Juin 2018 - 20:28
original thread: http://forum.generation-twingo.fr/t2274p50-fuite-liquide-apres-accident-plus-de-chauffage-et-ventilateur-inactif#67632
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 11 Juin 2018 - 21:38
I removed the 2 nuts of the exhaust manifold using a 13 mm socket, an impact wrench and a flexible extension.
I Better find new nuts.
Anyone knows an online store which can sell Renault parts?
Do I have to keep track of each of the 10 head bolts locations or I can mix them?
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyMar 12 Juin 2018 - 0:28
Easier than I thought.
C3g engine head removal (SUJET EN ANGLAIS)  Attachment
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyMer 13 Juin 2018 - 0:49
What do you think of the head, it has pittings and the black part on the left is sunken. C3g engine head removal (SUJET EN ANGLAIS)  Img_2010[/url]
Jean-Claude Duss
Jean-Claude Duss
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyMer 13 Juin 2018 - 8:22
Hi,
Do you easely find pieces for your car in Israel ?
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyMer 13 Juin 2018 - 8:37
This car was sold here for only 3 years with very small numbers. Very few still drives. Used to be easier. The dealer doesn't sell parts anymore. But I order from eBay mostly. It's much cheaper too anyway.
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyMer 13 Juin 2018 - 22:30
Does anybody know where those parts from the Ajusa gasket kit 52105000 should go?
C3g engine head removal (SUJET EN ANGLAIS)  Thumb10
C3g engine head removal (SUJET EN ANGLAIS)  Win_2010
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyDim 17 Juin 2018 - 23:32
My heating matrix is connected with the pants with the bleeding port connected to the bottom port and the other pants connected to the lower port.
But in this diagram it Should be the opposite. Can someone confirm the right connection?
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 18 Juin 2018 - 0:19
ok, I see in the parts diagram it is connected properly.
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyMer 27 Juin 2018 - 10:33
Does anyone know which gasket is suitable for my car?
There are 2 options for c06.
What does the cross sign mean?
C3g engine head removal (SUJET EN ANGLAIS)  2018-010
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 2 Juil 2018 - 12:50
check on ebay:80026 walker  click hier
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyLun 16 Juil 2018 - 13:49
Are there any torque specs for the exhaust nuts and studs? and for the pump bolts and temp sensor plates? and valve cover?
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyMar 31 Juil 2018 - 20:50
I don't know how to keep the gasket in place while putting the head back on, it's heavy and I've already ruined one gasket.
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyDim 5 Aoû 2018 - 20:38
I did it. You have to be careful and only lower the head over the gasket vertically. I used 2 drill bits to make sure the gasket is locked in place in 2 corners, I removed one of them by hand and one of them from the head hole with tweezers.
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyDim 2 Sep 2018 - 17:34
Man, putting back the spring and nut for the exhaust pipe was one of the hardest things I have ever done, I needed to use a magnet stick to get the nut to the bolt
M.Gibi
M.Gibi
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyMer 5 Sep 2018 - 20:49
Actually I found out it is easier to remove the nut from the bolt (a lot of WD40 or the like is required there), screw the bolt in the hole and then get back to fix the nut. Easier that way, I guess the bolt is too short to get in the hole with the spring unloaded.
Not at all easy, though =) I'd say removing that bolt and replacing it is probably the most awkward task in the whole operation
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyMer 5 Sep 2018 - 21:55
That's what I did. I screwed on new bolts when the head was off the engine. Still it was hard to hold the heavy exhaust in place while putting the spring and compressing it and screwing the nut over it.
ronenfe
ronenfe
MessageSujet: Re: C3g engine head removal (SUJET EN ANGLAIS)    C3g engine head removal (SUJET EN ANGLAIS)  EmptyDim 9 Sep 2018 - 16:24
I put everything back, I have sparks, the injector seems to work, but the car doesn't start. What should I do?
» Sujet: jauge essence ne s'allume pas en réserve.
» Fuite boîte à vitesse automatique
» Probléme d'allumage
» Ma Twingo manque de puissance et elle broute tout le temps
» [résolu]Filtre green ou KAD ( oui encore un sujet )
